- 2
Hi I was wondering if anyone has had a issue with a pro 4 keep loosing connection I’ve had a pro in the same place for years and I’ve just upgraded to a pro 4 I put it in the same place and it keeps dropping connection ?? It’s got the latest software on it and so does the base station all the other cameras on the network work. I can’t keep going up ladders to reset it it’s just not viable any help and advice I would appreciate thank you.
It looks like it. If you have an Android phone, you could get some more details on the signal strength (and competing signals) at the camera location using a WiFi analyzer. There are several free analyzers in the app store.
I have an iPhone.
@Amusjh wrote:
I have an iPhone.
As do I - unfortunately there are no free analyzers available for iOS.
There are some for PCs. So if you have a laptop, you could do a similar check (though of course it's not as convenient). Netspot has a free analyzer that is available for both Windows and Mac. https://www.netspotapp.com/
Coming back to this because I have yet been able to get this resolved and my cameras are not staying connected. Why would my Arlo Pro 4s have wifi interference and my original Arlo did not in the exact same location? I'm using the same mount for my Pro 4 that I had for the original one.
Do you still have the old camera? Might be worth putting it back as a test, and see if it stays connected or not.
FWIW, one difference with the Pro 4 is that it will need more bandwidth than the Pro 2 (due to the 2K resolution). I'm not saying that's the issue for you though.
Mukman,
Is the Pro 4 connected to a base station/SmartHub or directly to your home network?
Did anyone get a fix to these cameras disconnecting. Just bought a couple same problem. Tried with a hub and directly to internet still dropping.
Arlo has not fixed the problem. They were one of the camera solutions we were evaluating for a business campus deployment. They were eliminated from the cameras we are evaluating because of this issue.
My issues were reported in Jan/Feb. I provided detailed wireshark network traces documenting that the disconnection problem was due to the Arlo Application running Amazon servers in Europe. Even with this level of diagnostic information they have been unable to fix the problem. It appears that they have excellent hardware engineers but their software and network engineers are not qualified to work on cloud native based applications.
- 2
Arlo Pro 4
labels
Samsung SmartThings
