Are there skins available for the pro 4xl to help deal with condensation at nights?
Arlo doesn't make any, and I haven't seen any 3rd party options for the Pro 4 XL.
Is your primary concern about the camera seal? Or is it condensation on the lens affecting the video?
If the latter, RainX (or equivalent) can help some.
In addition, a skin isn't likely to provide any utility for condensation. The hood on them could help with the lens issue but Rain-X would be a better choice. Just don't apply it directly to the lens - use a cloth to wipe it on.
Arlo Pro 4
labels
Samsung SmartThings
