I bought the arlo pro 4 indoor charging cable and has it plugged in all the time. I took the battery out as I am not sure whether it kills the battery if it is continuously charged. It seems to work fine and I don't have to worry about charging battery. I guess the camera will stop working if someone unplugs it. I just wonder if it is ok to keep the battery in the camera if I have the indoor cable plugged in all the time. THanks.
Arlo says it is ok.
Arlo says it is ok.
Arlo Pro 4
labels
Samsung SmartThings
