Arlo Pro 4 XL 2.5/5 GHZ - mesh system advice
  • 1 Reply
  • 684 Views
Firefly99
About to purchase the Pro 4 as a standalone. Running a BT Smart Hub 2 with extender discs  - Mesh system. I have no ability to separate or guide devices   between 2.5 or 5 ghz. All automatic with one common SSID broadcast.
Question is whether the Pro 4 will work with a Mesh like this ? ...... Many thanks
It does work with my Orbi mesh (which also has only one SSID).
Though there is can be issues with onboarding generally.
  • 1 Reply
  • 685 Views
