@X1deere0378 wrote:
Do I have to have a subscription with these new ones?
Yes, the pro 4s will need a subscription if you want cloud storage.
can you buy a Arlo SmartHub or Base Station to avoid subscription with arlo pro 4
A smarthub (VMB4500 or VMB5000) would let you use direct access to local storage. Some folks do use that instead of a subscription, but there are several limitations:
- Recordings are only available in the app (not the browser)
- Recordings are only available from the primary account (not friend accounts)
- No ability to make manual recordings or snapshots
- No thumbnails, so you have to download the full video to get an idea of what it holds
- Remote access requires router setting changes that some find difficult (and which don't work on some networks)
A subscription also is needed for cloud activity zones (which is what you'd be using if the camera is running on battery).
Arlo Pro 4
labels
Samsung SmartThings
