  • 1 Reply
  • 2158 Views
Fredaf404
Hello Arlo community!
I'm in the market for a wireless camera to record a bird feeder station, and am wondering if an Arlo Pro 4 or similar camera could work for that. The cam would be mounted about 10' away from the feeders, and I would like to be able to view footage/clips from my smartphone if possible.
Does anyone have experience using an Arlo camera for this purpose? Any insight or recommendations would be much appreciated! Thanks so much!
A rather novel use of the camera but it should work fine. You may want to consider the cheaper Essential camera since it's just to be used for watching the bird feeder.
  • 1 Reply
  • 2159 Views
