  • 4 Replies
  • 1588 Views
Max2rik
How limited is recording on hub compared to iCloud?
@Max2rik wrote:
I am loathe to set up monthly subscriptions due to lack of funds however, I understand that I can save images to a smart hub therefore, what I am trying to establish is how well this will work? Thanks
Direct Access to local storage is outlined here: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Limitations are
  • You can only access recordings from the app (not the browser)
  • You can only access recordings from the primary account (not friend accounts)
  • You cannot make manual recordings or snapshots
  • There are no thumbnails
  • Remote access requires router setting changes that some find difficult (either a VPN or port forwarding).
You'll also lose activity zones if your cameras are running on battery (or solar panels).
Can you clarify your question?
Are you asking about retention?  Or something else?
Also, are you talking about local recording to a USB drive or microSD card on the hub?  Or about Arlo's cloud storage?
If local recording, then what base station/smarthub model do you have?
Max2rik
Thank you Steven for your swift response. I am unable to view library as my subscription has expired. I am loathe to set up monthly subscriptions due to lack of funds however, I understand that I can save images to a smart hub therefore, what I am trying to establish is how well this will work? Thanks
Limitations are
Max2rik
Thank you kindly, your response has proven very helpful.
  • 4 Replies
  • 1589 Views
