Will this connect to Arlo 2 Hub? I have 2 Arlo 2 cameras 1080 HDR. I want to add this pro 4 with 4k HDR
The base compatibility list is here: https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
The VMB4000 is compatible with both the Ultra and the Pro 4 (which are not the same cameras).
Then you want the Ultra 2, not the Pro 4. The Pro 3 and Pro 4 are 2K cameras, not 4K.
Note that the Pro 3, Pro 4, and Ultra cameras all require a paid subscription to get cloud recording.
What camera models are these? The Pro 2 is 1080p, but does not have HDR.
Arlo Pro 4
labels
Samsung SmartThings
