Arlo Pro 4 will not let me view our recordings anymore without a subscription
  • 1248 Views
superbike
Arlo will not let me view our recordings anymore without a subscription. I'm not getting a subscription. How do I bypass the message on the app?
Subscribe to a plan is the general answer. Alternatively, you would need to have the cameras connected to a hub with local recordings enabled so you can use the app to view them. Not the same as cloud recordings but it would mostly work.
boboreject
I'm having the same problems; my cameras are connected to a VMB4000 with local storage.
The VMB4000 doesn't support direct access to local storage via the app.  You need to eject the USB storage and connect it to a PC in order to view the recordings.
  • 1249 Views
