Arlo Pro 4 - schedule for a specific camera
Is there a way to set a schedule for a specific camera vs the entire system? The camera that catches my dog every time he goes out is crushing me. Thanks!
Yes. If you have a base station you
- Create a custom mode (let's call it Abner for the invisible dog) that includes all your cameras except for the one you want excluded. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
- Create a schedule that uses the Abner mode when you don't want the dog recorded, and uses armed the rest of the time. https://kb.arlo.com/4900/How-can-I-set-a-schedule-for-my-camera-in-my-Arlo-account
If you don't have a base station, you can just create the schedule (using disarmed when you don't want the dog recorded).
Note that a schedule entry can't span midnight - so you have to end the entry at 11:59 pm, and create a new one as 12:00 am.
Thanks so much for the quick reply StephenB! I went through the steps you outlined and it appears like I will still need to toggle between standard schedule mode and “Abner mode” daily? Meaning, I toggle to Abner mode when I don’t want the cameras to pick up my dog. And then switch back to full system armed at night (as an example). Am I getting that correct?
I ask because I had hoped to find a “simple way” to have, for instance, Front Door Camera and Back Door Camera armed all the time. But Side Door (or Abner) Camera turn on only at night when the dog isn’t out. And, have that be the default setting every day … meaning I would not have to switch back and forth between modes daily.
I may be completely missing a step … but am having difficulty doing this.
Thanks again so much for your help!
Best
Steve
No. You edit the schedule so it automatically switches between the Abner mode and the Armed mode at the times you choose.
Arlo Pro 4
labels
Samsung SmartThings
