Arlo Pro 4 - change cameras Wi-Fi without manually pressing the sync button
  • 1 Reply
  • 1858 Views
D_Beau
Is there a way to change a cameras Wi-Fi without having to manually get it and press the sync button? The instructions say to make sure the phone is on the network I’m setting the camera to, go in to settings > devices > connected to > change network and then follow the app instructions. Those include pressing the sync button on the camera. This is why I’m trying to avoid if at all possible (due to where these are mounted).
Depending on why the network needs to be changed, a simple solution is to use the same SSID and password on the new network as the old one. That obviously won't work in all situations so the sync button would be needed.
  • 1 Reply
  • 1859 Views
