Arlo Pro 4 cameras not loading
  • 1 Reply
  • 1144 Views
Miuku
Hi!
Do you have any idea why my cameras (connected with cables) won't load anymore? They are under 1 yr old so the battery should be fine. The one camera that is not connected with cable, is loading fine when I take it down.
I have cleaned the connectors, took the battery out etc. Should I just buy new batteries and cables, seems expensive after ~1yr usage.
BrookeN
When you say they are not loading do you mean you are not getting a feed/videos? Are they not picking up any motion? Can you explain more of what you are experiencing?
  • 1 Reply
  • 1145 Views
