Can I bread up a set of 3 Arlo Pro 4 XLCamera Security Bundle and put cameras at different locations? I'd like to put one at my home location and 2 at my warehouse location be able to use the same Arlo subscription. The cameras at the warehouse would work of a hotspot or cellular data, while the one at my home would be connected to wifi. I'm trying to decide if I can buy a bundle of 3 or if I need to buy the cameras separately.
Gidget 🙂
No problem. You can use the cameras at various disparate locations all in one account. A bundle of 3 is fine. Don't forget that a subscription will be needed once the trial sub times out.
The Pro 4 cameras don't connect to cellular, so you would need a hotspot of some kind.
There are also the Go 2 cameras, which can connect directly to cellular. They are 1080p, not 2K - but would avoid the need for the hotspot.
Thank you. That's helpful.
Arlo Pro 4
labels
Samsung SmartThings
