Arlo Pro 4 XL wich usb power adapter for charging ?
Hello,
I just purchased an Arlo Pro 4 XL. I connected the magnetic cable to a 5v 2A usb socket (telephone USB socket). I don't feel like my camera's battery is charging. The charging indicator in the Arlo app is OK (green) though.
Which USB adapter (Brand of charger) do you recommend I use?
Thank you
That should work. Are you seeing a lightning bolt on the icon in the app?
Arlo Pro 4
labels
Samsung SmartThings
