Arlo Pro 4 tiny hole between camera lens and spotlight
The front of the Arlo Pro 4 has a tiny hole located midway between the camera lens and the spotlight. The hole is not mentioned in the user manual. What is the function of the hole?
I believe it's the mic opening for 2-way communications.
Arlo Pro 4
labels
Samsung SmartThings
