Arlo Pro 4 XL bundle- hub needed?
  • 1 Reply
  • 1232 Views
a_ursino
I recently bought a Arlo Pro 4 XL bundle from Costco, but came with zero instruction.
  1. The 3 cameras will be installed on my rental property, and connected to my tenant's internet wifi network.
  2. Do I need to install the provided wifi SmartHub if I'm going to pay for their month cloud service?
  3. In short, is the SmartHub only required if I want to connect an external hard-drive onsite to store my recordings- as this makes my install much easier if not required.
@a_ursino wrote: Do I need to install the provided wifi SmartHub if I'm going to pay for their month cloud service?
No.  You can just set it aside.  I'd keep it for a bit, just to be certain.
You'll want to set up a friend account for the tenant to use:
If the tenant uses the main account, then they will be able to see the info of that credit card that you use for payment.
  • 1 Reply
  • 1233 Views
