I have the Arlo Pro now and can turn on and receive motion alerts on any of the 5 with my smart hub. I just purchased a 6 camera Arlo Pro 4 with a new smart hub. What do I need to do to now be able to get motion alerts and turn then on individually with 6. Will this work with a secure plan and will I need to not use the hub. I know the hub support is up to 5 simultaneous streams live or motion but I will not be doing them simultaneously. Thanks
You can do this either with a hub or without a hub (though it works a bit differently without).
With a hub, it works exactly as it does with your Pro cameras. Without a hub, each Pro 4 camera will have it's own set of modes, each of which has a rule for that specific camera.
Either way, you will need a subscription for cloud storage.
Arlo Pro 4
labels
Samsung SmartThings
