Arlo Pro 4 Spotlight camera - Which model number?
  • 1 Reply
  • 2620 Views
John-Padrus
All the intro menus for installing Arlo Pro 4 Spotlight cameras refer to chosing between VMC4050P or other VMC 40...... model numbers.
The Model number on the box is:
VMC4450P.
when I seek help for *my* device, (eg using the spotlight) which Model No. must I enter to get accurate & appropriate advice????
Thanks = John C.
VMC4450P.
The cameras are VMC4050P.  The extra 4 on the box is because you purchased a 4 camera kit.  You should be able to find the VMC4050P label inside the camera (don't recall exactly where, but perhaps behind the battery).
IMO very confusing.
  • 1 Reply
  • 2621 Views
