All the intro menus for installing Arlo Pro 4 Spotlight cameras refer to chosing between VMC4050P or other VMC 40...... model numbers.
The Model number on the box is:
VMC4450P.
when I seek help for *my* device, (eg using the spotlight) which Model No. must I enter to get accurate & appropriate advice????
Thanks = John C.
VMC4450P.
The cameras are VMC4050P. The extra 4 on the box is because you purchased a 4 camera kit. You should be able to find the VMC4050P label inside the camera (don't recall exactly where, but perhaps behind the battery).
IMO very confusing.
Arlo Pro 4
labels
Samsung SmartThings
