Arlo Pro 4 Not Auto Recording
Hi, I have 3 Arlo Pro 4 cameras set up to home WiFi, no base station. All three were working fine but a few days ago one of them stopped auto recording.
All three have the same settings as far as Modes go, and are armed, and have all have an active subscription.
I can live stream from the camera and manually record but it won’t do it automatically. I did a motion test and the light turns yellow. I took out the battery and put it back in. I deleted it from the app and reconnected it. I’m out of ideas. Any help would be appreciated.
Sounds like it's faulty. Use Settings, Support to start the replacement process.
Arlo Pro 4
labels
Samsung SmartThings
