Arlo Pro 4 Camera is not recording
I get live feeds so wifi is fine. It is wired. The blue light is on when nearby. The firmware is up-to-date. My subscription is up-to-date. I don't see any good solutions in the community. Can someone help or do I need to call Arlo support?
I'd check the rule for the camera in the mode(s) you are using, just to make sure nothing has changed there.
You might also want to remove power (charger+battery) for a few seconds in order to reboot the camera.
I have unplugged and power on again. No change. I have check the camera modes. All is fine
Can you make a manual recording while livestreaming a camera?
Camera will record manually…and passes the motion detection test…has an activity zone set…but does not respond to activity..
Have you checked the rule for the camera in the mode(s) you are using?
Arlo Pro 4
labels
Samsung SmartThings
