  • 4 Replies
  • 1366 Views
Retired_Member
Not applicable
Are there other wall mounts for the Pro 4 that will allow a greater angle allowance.  Some on amazon say they are for the Arlo Pro 4 but I dont see how they would work. Thank you.
The threaded mounts are the ones with the most flexibility. Have you looked into those?
Retired_Member
Not applicable
Yes I have. I just dont know how to connect them to the camera body that I have. (Pro 4)  There is no way to detach the mount that's on it. That is why I was leary about buying them from Amazon eve though it says they are supposed to fit according to the description.
Are your cameras ones that have the security mount? If so, you'd have to remove the housing and replace it with a normal housing (https://www.arlo.com/en-us/accessories/VMA5202H-10000S.html for instance) would allow you to then use the threaded mount.
Retired_Member
Not applicable
Tha would be another $100 expense and then the wallounts on top of that. It's not looking good. Thank you for the info. I appreciate it.
  • 4 Replies
  • 1367 Views
