Arlo Pro 4 Camera-Spot light doesn't come on during motion detection
  • 1 Reply
  • 250 Views
RaginCajun5583
I checked the settings and all are set to come on when motion is detected. It will only come on during a live stream when I tap the light button. Otherwise won't come on. Battery is @ 100%, can see everything else in the live stream. It was working fine til a few days ago, and quit working. Any ideas? Thanks
ShayneS
Hi @RaginCajun5583
Are you still experiencing these symptoms?
  • 1 Reply
  • 251 Views
