Picture In Picture on Samsung Smart TV
I have Arlo Pro 4 Cameras and wired doorbell, with arlo secure with feed app for 3 cameras -
Live View appears (sometimes) on my Samsung Smart TV in the small Picture-in-Picture window.
When motion is detected it has appeared in the small Picture in Picture popup window a few times, and disappeared after maybe 10 seconds.
It seemed to work sometimes after I had either setup the cameras in smartthings, or... after I setup cameras in my Alexa App. I've tried both or just one or the other.
I have no clue as to why, or how to make a camera show in the small picture in picture when motion is detected. I just know it has come up a few times in the small picture and then stopped coming up at all.
I can setup a motion detection routine in the Alexa App on Iphone that works for full screen.... but not for the small 'Picture in Picture' popup view. (some call it multi-view)
I have tried everything i can think of... Deleting and re-installing cameras in everything and linking and unlinking with smartthings app, alexa app, and the arlo secure app with feed for 3 cameras.
Does this affect all your devices on your Smart Things integrated account?
All devices are affected.
Last week I 'logged off' of integrated smartthings' on my TV to try some Alexa App routines on my Iphone.
I did figure out a few things by making Alexa Routines on my Iphone.
Inserting a 'comma' between pip and minimized made the view show, then minimize, then go away on my TV.
I made this test routine for 'front cam detects motion'
Added the following 3 actions -
Show front cam in pip, minimized
Wait 10 seconds
dismiss pip
choose Hear Alexa from
Fire TV Cube gen 2
Somehow this was happening with smartthings but haven't figured out how to do that yet.
This Alexa routine works when I am watching YouTube TV thru my Fire TV Cube gen 2 on HDMI 1, and that has something to do with it also.
Also Alexa is a connected account in the Arlo secure app.
Can you verify that you hav enabled notifications for required devices on the SmartThing app on the TV? You can find more info here: https://www.samsung.com/ph/support/tv-audio-video/how-to-use-the-smartthings-app-on-your-samsung-sma...
Arlo Pro 4
labels
Samsung SmartThings
