Using an Android Phone and Kindle Tablet to access this camera. Camera has latest software installed; have had the camera for
You can adjust the speaker volume by navigating to Devices > Select the camera > Settings (Top right) > Audio Settings > Volume
Does this help with the outgoing audio?
No, I have already done this and no changes in output audio at all. Input audio is great!
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Arlo Pro 4
labels
Samsung SmartThings
