kevinh2003
Set up Arlo Pro 4 at bird feeder a couple of weeks ago. Initial image was very clear. A couple days ago the image became very pixelated with poor resolution. I cleaned the lenses and camera face an nothing improved. Set up a second camera today and it is also very low resolution. I have selected the battery power option for highest quality video.
130 REPLIES 130
Bjohnson6626
I'm experiencing the same problem with my cameras. They worked great for 6 months, now all 3 cameras are blurred. I've tried everything that you were told to do do with no solution as well. I believe it's a firmware issue or the cameras are faulty. I have 5 arlo 2 cameras at another house and they work perfectly fine for the last 4 years. Let me know if you get a response from Arlo with a real solution.
ShayneS
Thank you for the updates, the team is investigating this at the moment and I will provide any updates as soon as received.
countrygirltwo
This has been a real problem for the last month as well for me.  You can’t make out really anything in the video as it is so pixelated. It’s super frustrating and hoping there will be a fix asap.
I have also completed all of the necessary troubleshooting.
For the price of the monthly plan to have the video storage it is certainly not worth it if the video is not even viewable and so pixilated.
Mammoth670
imagine having just switched to a yearly plan.
(yep thats me)   right when this happened
countrygirltwo
I was thinking of doing that just to save money because the price plan jumped so high.
I have owned Arlo’s since they first came out and I’ve never been so disappointed.
I really hope they get a fix soon because there is no way I could even use the video if I wanted too.
Rfm8766
I’m also having issues with pixelation of image. Have tried all the above and nothing makes it better. I plugged in my Wyze cam right next to it which only records at 1080p, not 2k and the image quality is insanely better which should not be the case. Definitely would like to see this resolved asap because in its current state the images/recordings are utterly useless.
Mammoth670
My cameras all just did an update... keep your fingers crossed!
I walked downstairs and one was blinking orange and blue
Mammoth670
i have no way to update/ edit my previous post that i can see.
if there was an update applied.   it did not fix anything with the original complaint of fuzzy/ blurring of playbacks on my camera
dillbrit
i am having the same problem with arlo pro 3 floodlight.everything has been great for over a year,now for couple months i cannot see anything video is terrible.have done all the troubleshooting.you have a problem with multiple of your products.what are you doing to fix this?
dillbrit
i am having the same problem with arlo pro 3 floodlight.everything has been great for over a year,now for couple months i cannot see anything video is terrible.have done all the troubleshooting.you have a problem with multiple if your products.what are you doing to fix this
ShayneS
@dillbrit1
May I ask which troubleshooting steps you have performed so far?
dillbrit1
i have given the camera a full charge.removed and reinserted battery several times.removed device from the app and reinstated it several times.i have reset my router several times.i have checked the connection several times,which is always good,currently link rate is 65mbps.i have brought it right next to the router with no change.it is up to date on updates.i have gone through all the settings and tried all the options,nothing.yes power management is in best mode.night vision and auto zoom are off.bandwith is at strong.flicker adjustment on auto.i cleaned the lens and housing unit.
ShayneS
@dillbrit
Is it possible ti provide a screenshot of the pixelation?
dillbrit1
QuinnLee512
I just took the plunge and replaced all my Google nest cameras with 6 Arlo Pro 4's. The 2k image quality is noticably worse than the 1080 of the Nest. It looks pixelated especially when zooming in. Very disappointed. I hope this gets fixed soon.
QuinnLee512
Here are some sample images at 3x zoom. The video quality pulses between bad and worse.
I've seen a similar sample - in that one, it was clear that the i-frames (send every two seconds) had too low a bit rate.  That caused the blurring out/pixelation.  The following p-frames built back up the image quality, but it blurred out again at the next i-frame.
This is on Arlo's escalation list, not sure how long it will take them to fix it.
Mammoth670
all of my cameras did another update this morning
ShayneS
Hi,
Are we still experiencing this issue with the latest firmware released May 30th? 1.080.19.2_40_a462be1
Mammoth670
yes.    it is still an issue for me along with the Cicada sound on random videos where the microphone is enabled
QuinnLee512
Still an issue. Confirmed firmware version. New screenshots attached. Looks really bad. 3x zoom.
ShayneS
Thanks for the updates, I will notify the team.
MichaelTee
Installed a new pro 4 last week. I've never had a clear sharp image. It changes from bad to worse every 2 seconds. Attached images are at 2x zoom. Version is 1.080.19.2_40_a462be1.
Cltlee
I am also experiencing the same issues as others. I installed the camera early May and never has looked good and is very pixelated. Running version 1.080.19.2_40_a462be1
Thanks for your help!
Billycrk
I am joining the multitude of Arlo Pro 4 owners who have noted a drop in picture quality with pixelation over the last couple of months.  I have tried to set to highest picture quality on battery settings with no success. It also no longer allows me to zoom the camera.  What is happening? Last year the picture quality was much better.
