  • 7 Replies
  • 1282 Views
Wmine
Good luck trying to get meaningful support or warranty service.
Camera doesn't work regardless of how many times you reset it or follow all the steps.
More then ten emails from ARLO asking me to go to support and try all the steps again and again.
Insane!
No more ARLO for me.
7 REPLIES 7
ShayneS
Hi @Wmine
I have escalated your case & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here:  44150222
Dthomas29
Yep same here. I’ve had a few cameras work for months then just stop and no amount of updates or resets have helped. Support is crap & I’m ready to trash the cameras.
ShayneS
Hi @Dthomas29
Can you provide more information regarding the symptoms you were experiencing?
Dthomas29
Yea I have had 4 of my 6 Arlo pro 4 cameras just stop connecting to the internet & wont sync back when resetting. After constant disconnects & an hour of messaging, they kept wanting me to do more. I shouldn’t have to do crazy run arounds to get my devices working when it’s happened with more than 1.
Edinburgh_lad1
Hero
Hero
If it's happened to all of your cameras, then this suggests a problem with your setup/network/account. Statistically, it's unlikely that all cameras would break all at once.
Dthomas29
All cameras have not broke at once, this has happened to 4 cameras over the course of 5 months. If it was my setup in some regard, I would not still have 2 cameras working & cameras randomly not working (and not connecting again after hard reset) while others are still connected to same network.
ShayneS
@Dthomas29
I have escalated your case & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here: 44152820
  • 7 Replies
  • 1283 Views
