I have just start to activate my 3 cam Arlo Pro 4.
The result is:
- 1 cam it is detected and it's running
- 2 cams they are not able to be detected. I passed this step:
- insert battery, blu light => OK
- reading QR code, sound => OK
- detection, KO => cameras blink a blu light for less than 30 seconds, than a red light start to blink and after 10 seconds cameras seem switched off and my device (laptop or mobile) continous to try to detect cameras with no result.
What can i do?
Marco
@Vette1 wrote:
Bought and connected Pro3 Floodlight camera on the app, tried to connect the other 2 cameras (Pro-4) 2 wire free spotlight on the app on the same WiFi and … nothing. Won’t read the barcode.
Have you tried a PC browser (my.arlo.com)?
Il have the same problem.
I used a pc. Still the problem.
Only one cam has been detected.
Arlo Pro 4
labels
Samsung SmartThings
