On the app, when you are looking at all your camera's, what is the number that is inside the circle that is next to settings icon for each camera on the right side?
It is the number of new recordings since you last checked the library. Once you check the library it goes back to 0.
Arlo Pro 4
labels
Samsung SmartThings
