My app does not show a "Library" category. How can I select ALL my daily videos / notifications in order to delete them?
"Feed" (the new user interface) unfortunately doesn't have that feature. There has been quite a bit of feedback from the community that it needs to be added. Hopefully it will.
There is a way to delete all cloud recordings (all days, no ability to select) - look in the privacy center for that. That might be more than you want though.
It's worth a try...
Arlo Pro 4
labels
Samsung SmartThings
