All 8 of my camera stop working due to hub went off. When i went to reset smart hub it erased all camera.
Are you able to add them back?
Resetting the smarthub with a paper clip will restore it to factory settings, so you do need to remove any cameras paired with it (if the system doesn't do that for you) and then add them back.
Arlo Pro 4
labels
Samsung SmartThings
