  • 2 Replies
  • 1525 Views
bhosay
Nov 7 iOS app update v5.2 issues with STATUS ICONS of CAMS ; PRO2 & PRO4 & PRO5s cams, 22 total.
very random issue with 1 or more cams will NOT show CAM status icons or name in DEVICE view,
initial entry into DEVICES(even if wait 30+ sec) none of icons will show until scroll up/down then most but not all will update icons.
I turned OFF both stations & iPhone, same symptoms after all back ON.
NOT specific to any 1 cam or station.
Been using ARLO since 2016, never seen this type symptom; NOT extreme crisis, just obvious after update that NO white icons or name was shown on initial device view of cams.
BrookeN
Can you please try to uninstall the app and reinstall it and see if the behavior you are seeing changes?
bhosay
app release v5.2.1 fixed the issue, first time open DEVICES then all cams had status icons immediate available
  • 2 Replies
  • 1526 Views
