1 Pro 4 camera connected, 2 won't
baffled. I managed to get one of Pro 4 cameras to connect. The other 2 won't! baffling. both read the QCR code, then I'm told after a couple of minutes that it can't find the device. Either of them. I tried it both on the website and on my phone. Help?
Are you seeing the camera in your router's attached device list after you hear the chime?
Sometimes you end up with a space at the end of the network name (or password) - hard to spot, and the app doesn't trim it.
Arlo Pro 4
labels
Samsung SmartThings
