Finally got the Pro4 recognized with my WiFi....what's next?
How do I see or know when the camera is recording? I don't have a subscription & the details are pretty sketchy to non existent.
Does the camera display a picture using the app main page? If you’re using the mobile app you should be able to tap the image to show a play button to begin a live viewing of the camera.
You can go into mode page and set it to “armed” mode so the camera will trigger motion push notification events to your mobile device.
If the camera has a subscription trial you should be able to see recordings appear in the app library which is part of the arlo cloud library paid feature.
I will see if I can get that to work. Thanks!
Arlo Pro 4
labels
Samsung SmartThings
