can i add Pro 4 cameras to my pro 3 system
I have 4 Pro3 cameras on my substation and want to add a few more but 3's are going out and I can get Pro4's at a good price. Will these work with existing system and can I add a Go2 camera as well?
Any base/smarthub that is compatible with a Pro 3 is also compatible with a Pro 4. The Pro 4 can also be connected directly to your home wifi if you wish.
The Go 2 camera can't connect to any Arlo base/smarthub. But it can connect to your home wifi (and of course mobile data).
