Arlo pro 3... why can’t I take a snapshot or start a recording?
DIsabling 2k live view doesn't disable live view itself - it just uses 1080p instead of 2k.
If you have 2k live streaming enabled, those options don't appear.
Thanks. I’m a newbie so I’m a bit confused. If I disable that function I can’t watch the cameras live, so taking a picture or recording is only something you can do when looking at your library? I would think one would want to take a photo of something they see live to view later? Why would t someone want to keep the live streaming?
