@Chris999999 wrote:
I get this error Videos stored on base station not available. I have 2 arlo pro 3s and a wired doorbell connected to the base station. I can’t view any recordings from my base station. I already tried restarting the base station and reinstalling the app. What else has everyone tried?
Are you running iOS or Android?
Is this happening
- when the phone is on your home wifi?
- when away from home?
- both?
@Chris999999 wrote:
Tried on iOS and android , home WiFi, haven’t tried it away from home
And with both iOS and Android, you can select the base as the library, but then get this error message?
@Chris999999 wrote:
iOS I can select either cloud or base station to view. Android just says library
Is the Android phone using a friend account? Only the primary account can access the local recordings.
@Chris999999 wrote:
iOS I can select either cloud or base station to view ... and I can’t view ...
I suggest restarting the base, and see if that helps.
If it doesn't, then try ejecting the storage, and making sure the recordings are there (connecting it to a PC).
@ByronHChen wrote:
Please let me know what else I can do? Thanks!
I can't think of any other troubleshooting steps. Of course getting a subscription would be a workaround, but you would need to pay for that. It would get you the videos, and also entitle you to phone support.
