I am upgrading my Arlo Pro system to Arlo Pro 2 and I am debating which base station to keep for future upgrade.
From the article, the older base station VWB4000 supports streaming for Arlo Pro 3 in 2K but the newer base station VWB4500 that comes with Arlo Pro 2 does not. I want to make sure that is indeed correct before keeping the old base in case I will add Pro 3 camera in the future.
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
The Arlo base stations with siren are compatible with Arlo Pro 3, Pro 2, Pro, Wire-Free, and Arlo Audio Doorbell.
VMB4000
- Stream in 2K when paired with Pro 3
- Store recordings locally with a USB device
- Features integrated Smart Siren
VMB4500
- Stream in 1080p when paired with Pro 3
GunLok,
This is correct, at this time, VMB4000 allows for 2K streaming with a Pro 3, VMB4500 does not.
GunLok,
