  • 5 Replies
  • 5923 Views
  • 2 Likes
ralfyguy1
Virtuoso
Virtuoso
I currently have 4 Arlo Pro2, 5 Arlo Pro and 4 Arlo cameras on a VMB4000 base station. I have two questions:
1. Can I get access to the Local Recordings without unplugging the USB Drive if upgrading the VMB4000 to the VMB5000 Smart Hub?
2. Does the VMB5000 Smart Hub have as good of a signal coverage as the VMB4000?
The VMB5000 uses microSD and not USB.  But you can access the recordings w/o removing the card.  https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
I haven't noticed any difference, though my cameras aren't that far from the base.
FWIW, I suggest holding off a bit on upgrading the base.  Direct Storage Access is new, and there are some issues with it that I hope Arlo will address.  One is the lack of thumbnails, another is that it doesn't support "grant access".
Though 13 cameras is a lot for one base.
5 REPLIES 5
michaelkenward
Sensei Sensei
Sensei
Also missing from Direct Storage Access is local access with your browser on a desktop PC.
A serious shortcoming by my reckoning.
Just another user
ralfyguy1
Virtuoso
Virtuoso
Well, that's not what I envisioned. No PC Access makes it useless to me then.
michaelkenward
Sensei Sensei
Sensei
Indeed.
Maybe this is something else, like thumbnails, that will get fixed in the future.
Just another user
FWIW, I agree PC access is needed.
  • 5 Replies
  • 5924 Views
  • 2 Likes
