VMB4540-100AUS - problems connecting the smart hub to wifi.
We are having problems connecting the smart hub to wifi. We have factory reset, powered down, followed instructions and still have a flashing amber light. Any suggestions?
WiFi? The smart hub is connected via ethernet to your router.
Have you tried using a different cable, or connecting to a different router LAN port?
