Using more than 5 devices in India
Hi,
I'm a user from India, currently using 2 Arlo Go's and 2 Pro 2's on a free subscription plan. I'm planning on adding 4 more cameras (Pro 3's). Is this supported on a free subscription plan? If not, what are my choices, as the paid subscription plans aren't available in India.
Thanks.
The Pro3 cameras for best usage need a service plan....
read this;
https://kb.arlo.com/000062366/New-Arlo-Smart-subscription-plans-FAQ
No. Pro 3 systems do not get free cloud access.
If Arlo does not offer subscriptions in India, then you will not get the "free" introductory offer.
You might do better to buy some more Pro 2 cameras, but they have a five camera limit.
As @TomMac says, read the official information.
Arlo subscription plans and cloud recording
check this too:
What is Direct Storage Access and how do I use it?
Just another user
