Question about scheduling - Pro3
When I create a schedule what happens when that event is over?
For example: If I set my system to ARMED mode from 8pm-8am what mode does it enter after 8am if nothing else is scheduled?
If a MODE is not active, the camera is OFF
Are you saying that if I put it in schedule mode and the scheduled time comes to an end, the system changes modes to DISARMED?
Your answer is confusing bc the schedule can be set to DISARMED which means when that when my schedule is over it would just stay disarmed? I guess it makes sense if there is more than one period of being armed with disarmed scheduled mixed in. I’m going to run some tests.
Yes, if there's no mode in any time period, the system is disarmed. You must have a mode selected to activate any cameras.
Ok that does make sense. Thanks for the responses.
