Thinking of the power requirements for the USB maybe exceeding the base station capacity.
I recall the size needs to be 16GB minimum and no larger than 2TB.
FAT32 is the format ideally used, although was it formatted on a PC platform rather than with the arlo app?
How are you switching between arlo cloud storage and local storage?
Thank you very much for the response. I have a 16GB, 128GB Sandisk and an amazon 2 TB all USB sticks. I tried an external hard drive as well. I formatted them all in the arlo base via my laptop. I think i tried the app at one point too.
I get a message "Insert a USB Flash Drive into your New Base Station to start storing recorded clips locally." after it is working perfectly for 10mins or so.
I toggle from cloud to local in the library on the laptop or app.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
