Subscription prices
I just turned on my cameras I’m not sure which subscription to pick it looks like there’s two different subscriptions you can pick from it looks like there’s a secure one and then another one underneath on the main page can anyone help me and tell me which I can choose from if I pick the one on top for 1299 a month does that record or do you have to add the CVR as well I’m very confused
Best to wait until the trial subscription expires (getting the most out of the free trial).
Most subscribers just get Arlo Secure.
CVR (continuous video recording) requires that the camera be connected to AC power. Although it's been a while since I tried it, I wasn't really a fan. There are dropouts, and navigation of the timeline is tedious. Also, there is no way to download a section of CVR video. It is also quite expensive (you need a subscription for each camera).
That said, it is a different subscription from Arlo Secure, and if you also want motion recordings you'd need both.
