  • 7 Replies
  • 2572 Views
Nizab
Can anybody help me how to control the sensitivity on my pro 3 I get +100 recordings on sound a day
7 REPLIES 7
Do you want/need audio detection for your cameras? If not, go into your modes and edit the rules to turn off audio detection while leaving motion detection on.
Nizab
Thanks for the advice, if it would be possible just to lower the sensitivity and still keep the noise detection on, it is the wind that courses the problem, I have pro 2 with no problems but pro 3 is giving me problems
Different hardware/firmware so I wouldn't compare too much. WHat is your audio detection setting right now? Have you tried lowering it?
Nizab
I can only find mic on or off, but
not where I can set sensitivity, any advice ?
The sensitivity settings depends on which user interface (UI) you're using - the old one uses Library to view recordings while the new one uses Feed.
For the old UI, you need to edit your modes and rules:
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
For the new UI, edit the camera settings in Default Mode Settings.
Nizab
Thanks a lot for the advise, I did turn down the sensitivity to 1 and I did help but for this one camera it still detectes to much noice. I have tried to move the camera to where one of my other cameras are with no problems, still the same it looks like the pro 3 is just to sensitive.
FWIW, I find there is too much street and wind noise for audio detection to work properly for me (with any camera model).  So I just keep it disabled.
Wind is tricky, since the wind itself will move the diaphram on the mic (so not just the sound the wind makes).
  • 7 Replies
  • 2573 Views
