I am wanting to purchase the arlo pro 3 -4 cameras- with smart hub.
Question: can I keep the base station and two cameras at my current home and take the other two cameras and set them up on my WiFi at my other property?
Yes, that should work fine.
The Pro 3 cams need to connect directly to the hub on it's own wifi network. . The Pro 4 and Essential series can connect directly to your wifi without a Hub in your other property.
I figured it would but wasn’t sure.
Then someone below said it won’t work so now I’m confused😂🤦🏽♀️
It would work but you would need a second Hub/Base at the other property. Not sure if that is what you want as the Pro3 only connects the the Hub. A Pro4 can be used without a Hub/base at the other property without buying a second Hub/base since it can connect to your wifi.
