  • 2 Replies
  • 1560 Views
Growit4u
When Pro 3 was first installed it recorded for a week...Hasn't been recording ever since....how do I fix this?
dcfox1
Not much to go on some details will help. Is it a new install and what have you tried to troubleshoot?  You can try removing the battery and reinserting then try removing the cam from hub and resyncing it. Also are saying there are no recordings in library at all?
Cranes
Sounds like the "do nothing" is your issue. STart by rebooting your hub. Read the FAQs here on modifying modes and rules as well as creating your own custom modes. Edit your modes and rules to get exactly what you need.
  • 2 Replies
  • 1561 Views
