  • 1426 Views
gijerhome
My arlo pro 3 live stream function is not working after firmware update.
One of the devices has also been disconnected and I can't reconnect it.
I've tried to reset everything but it doesn't seem to work. Can someone contact me ASAP to solve this.
WHat happens when you live stream? Have you restarted the camera or hub? Have you reinserted the camera battery? You may need to remove and reinstall the camera in your account.
gijerhome
I’ve tried these all. But I don’t dare to remove all the devices as I tried to remove one of them but now I can’t reconnect it!
Since you seem to have multiple issues, I would remove all devices in Settings, My Devices and start fresh. That's a PITA but clears out weird things. If a camera doesn't reconnect it may be faulty so use Settings, Support to start the replacement process.
  • 1426 Views
