Pro 3 battery might stuck on
  • 793 Views
Lani1
my battery indicator light is enabled.  I keep my camera plugged in to keep the battery at 100%.  The battery light came on and stayed on for a few hours, then turned off even though the app shows the battery is still at 100%.
What could be the problem?
I'd remove all power (including the battery) and then add it all back again to reset the camera to a known condition. Keep an eye on it to see if that makes a difference.
Lani1
thanks for the suggestion....  tried that already a few times.... same problem
Do you have another Pro 3 (or Pro 4/Ultra)?  If you do, try swapping the battery, and see if the problem moves with the battery or stays with the camera?
  • 794 Views
