I am getting ready to purchase 6 Arlo Pro 3 cameras. My questions are : Can I have these 6 wireless cameras running all at once at one location (my home). I know if after a free 30 day trial of the Arlo secured plan, do I have to purchase 6 secured plans or just 1 plan that covers all 6 camera's. Lastly, would it be beneficial for me to buy a hub for 6 cameras?
Thank you for any help !!!!
Tall P
Pro 3 cameras (which have a small spotlight)? Or Pro 3 Floodlight cameras.
The floodlight models can connect directly to your home wifi. The Pro 3 cameras require a hub.
Details on plans depend on your country, so you should check www.arlo.com.
In the US (and several other countries) you can get a plan that covers all the cameras at a given address.
There are some countries (I believe Switzerland is one) where the multicamera plan is limited to 4 cameras. I don't know if folks in those countries can get two multicamera plans or not - I'm tagging the mods ( @BrookeN , @JamesC , @ShayneS ) so they can clarify that.
You do need one for the Pro 3 (spotlight) cameras as I mentioned above.
There are a couple of features that require a hub
- direct access to local storage (VMB4540 and VMB5000 only).
- Apple HomeKit integration
- Continuous Video Recording (CVR)
CVR requires its own subscription (one for each camera), and also requires that the camera be connected to AC power.
The main downside of a hub is that it doesn't have as good coverage as a mesh wifi network. Depending on camera placement, you might need more than one hub. A second downside is that the hub can only handle 5 simultaneous streams. So you wouldn't be able to record all 6 cameras at once with one hub.
If you do decide to get one, I suggest the VMB4540 smarthub for these particular cameras.
